According to the Quick Start Guide, one should enable encryption by adding a password to the D-Ext band settings, and this results in a blue LED on the MoCa status light.
However, I have also added a password to the D-Low and D-High items, and now the LED is white.
I'm mostly just curious what is the difference, and should I not have a password on D-Low and D-High?
I was looking for something new among the well-known online casinos and accidentally came across this site. https://www.casino-sistersite.co.uk/party/ has everything you need to get off to a good start - a brief overview, basic information about bonuses, and easy navigation. Everything is clear and without water, so you can quickly navigate before playing.
LED white is not correct. If the encrytion is enabled, it should be Blue.
The default band is D-ext, you can enable encryption on D-ext. You also can enable encryption on D-Low and D-high, it doesn't matter.
