Hello-
I have a new Actiontec WCB6200Q connected to a new GoCoax WF-803M directly with a coax cable (no splitters, no wires thru my house... one cable connecting the two boxes). both are plugged into power. The GoCoax WF-803M is plugged into the router via ethernet.
On both devices, the MOCA light is not lit up. The power/wifi/LAN lights are all on. Ive used the WCB3000N wifi adapter with the same GoCoax wf-803M and it was literally plug and play.
What am I missing here?
You must have an ONT because you are a Frontier FiOS (fiber) client, but which router are you using slope game? Model number?
WCB6200Q used a very old MoCA chip. To work with it. You have to configure our product to D-band low mode.
Please follow these steps:
• Set a fixed IP to your computer, such as 192.168.254.10. You can follow the guide to configure the fixed IP.
• Connect your computer to the LAN port of MoCA adapter via ethernet cable.
• Visit http://192.168.254.254, username is admin, password is gocoax.
• Go to the ‘MoCA Settings’ page
• Deselect ‘D-Ext’ and ‘D-High’, only keep ‘D-Low’, save the configuration.
• Reboot the device,
• After boot up, connect MoCA adapter to your coaxial network. Wait for about 2 minutes.please check the MoCA link and traffic.
Waiting for your feedback,
