Hello, I'm unable to get my MoCA light to turn on. I've viewed other posts like this, but unfortunately none solved my problem. My current setup is a Spectrum Modem > Splitter, Modem > Router, Splitter > MoCA, MoCA > Router, Splitter > Wall. The power and Ethernet lights are on and working fine, it's just the MoCA one. I've also tried a second one (since I had to get two as my router doesn't support MoCA) and tried it just in case one was faulty, and unfortunately that didn't work either. And if you're wondering, the model number of my router is: ASUS RT-AC1900P AC1900. Any help is greatly appreciated!
Comments (2)
MoCA adapters sometimes have a reset Drift Hunters button. You might want to try resetting the MoCA adapters to their default settings and then reconfigure them.
Sorry for late reply.
Normally, you need connect one MoCA adapter to router. Another one to your computer. and connect both of them to a splitter.
You can do a quick check to make sue the MoCA adapters are good. Connect the two MoCA adapters directly with a short coaxial cable. Wait for 2 minitues, check the MoCA light.
If the MoCA adapters are good, Let's check the splitter and coaxial cables.
