Hi,
I'm experiencing issues with random connection drops and degradation, and wondering if anyone from Gocoax might be able to assist.
A network diagram is below - there are no other coaxial devices besides the modem and adapters.
Additionally, the XB8 modem has been placed into Bridge mode, so it should not be outputting any MoCA signals.
On the MA2500D hooked up to the router, I have "Preferred NC" ticked; on the others, it is off, the Link Rates chart from the adapter connected to the modem is below:
On the router's log, during some (but not all) of the instances of connection issues, the router notes that the host adapter loses its connection - "ether8 link down" followed by "ether8 link up (speed 1G, full duplex)"
In other cases, the adapter hooked up to the RT-AC86U will go down, with the Asus logs reading "eth1 Link DOWN", "eth1 Link UP 10mbps full duplex", "Link DOWN", and then finally "Link UP 1000 mbps full duplex."
There doesn't seem to be a rhyme or reason as to when or under what conditions things will go wonky. Is there any way I can try to pin this problem down?
Max88 là một trong những nhà cái trực tuyến nổi bật và được yêu thích tại châu Á. Với sự phát triển không ngừng và sự đổi mới trong dịch vụ, Max 88 đang khẳng định được vị thế của mình trong ngành cá cược trực tuyến.
I am sorry for hijacking the thread but I am facing the same exact issue with the MA2500D connected to a Mikrotik that does not have the option to disable EEE. With other devices that do not use EEE it is OK. Firmware version is 2.0.13.0 Anyway to fix it? Otherwise I will have no option but to return them as it is a brand new purchase.
Writing to update. Issues persist, I appear to have resolved some of the issues by turning off EEE and STP on the Asus routers. I was only able to turn off STP on the Mikrotik, it doesn't have the option to switch off EEE/802.3az, and forced the interface to only advertise 1Gbps since it is a 1G port. The link down/up continues multiple times per hour, see below.
A competing manufacturer, seemingly on the same or similar MaxLinear chip, released an update which notes "EEE Disabled to fix EEE caused frame loss," is it possible that a similar improvement could be put into the next goCoax firmware? I am left to assume that this is the problem since the Asus routers have been behaving once EEE is turned off.
07-08 02:43:52 interface,info ether8 link down 07-08 02:43:55 interface,info ether8 link up (speed 1G, full duplex) 07-08 03:00:33 interface,info ether8 link down 07-08 03:00:36 interface,info ether8 link up (speed 1G, full duplex) 07-08 03:06:38 interface,info ether8 link down 07-08 03:06:41 interface,info ether8 link up (speed 1G, full duplex) 07-08 03:51:36 interface,info ether6 link down 07-08 03:53:32 interface,info ether8 link down 07-08 03:53:35 interface,info ether8 link up (speed 1G, full duplex) 07-08 04:00:19 interface,info ether8 link down 07-08 04:00:21 interface,info ether8 link up (speed 1G, full duplex) 07-08 04:00:22 interface,info ether8 link down 07-08 04:00:25 interface,info ether8 link up (speed 1G, full duplex) 07-08 04:06:55 interface,info ether8 link down 07-08 04:06:58 interface,info ether8 link up (speed 1G, full duplex) 07-08 04:23:12 interface,info ether8 link down 07-08 04:23:16 interface,info ether8 link up (speed 1G, full duplex) 07-08 04:57:10 interface,info ether8 link down 07-08 04:57:13 interface,info ether8 link up (speed 1G, full duplex) 07-08 05:51:32 interface,info ether8 link down 07-08 05:51:36 interface,info ether8 link up (speed 1G, full duplex) 07-08 05:58:03 interface,info ether8 link down 07-08 05:58:06 interface,info ether8 link up (speed 1G, full duplex) 07-08 06:06:24 interface,info ether8 link down 07-08 06:06:28 interface,info ether8 link up (speed 1G, full duplex) 07-08 07:11:07 interface,info ether8 link down 07-08 07:11:11 interface,info ether8 link up (speed 1G, full duplex) 07-08 07:47:56 interface,info ether8 link down 07-08 07:47:59 interface,info ether8 link up (speed 1G, full duplex) 07-08 09:09:51 interface,info ether8 link down 07-08 09:09:53 interface,info ether8 link up (speed 1G, full duplex) 07-08 09:11:39 interface,info ether8 link down 07-08 09:11:42 interface,info ether8 link up (speed 1G, full duplex) 07-08 09:44:04 interface,info ether8 link down 07-08 09:44:06 interface,info ether8 link up (speed 1G, full duplex) 07-08 09:45:30 interface,info ether8 link down 07-08 09:45:34 interface,info ether8 link up (speed 1G, full duplex) 07-08 09:54:39 interface,info ether8 link down 07-08 09:54:43 interface,info ether8 link up (speed 1G, full duplex) 07-08 10:09:14 interface,info ether8 link down 07-08 10:09:17 interface,info ether8 link up (speed 1G, full duplex) 07-08 11:55:50 interface,info ether8 link down 07-08 11:55:54 interface,info ether8 link up (speed 1G, full duplex) 07-08 12:42:13 interface,info ether8 link down 07-08 12:42:17 interface,info ether8 link up (speed 1G, full duplex) 07-08 14:11:59 interface,info ether8 link down 07-08 14:12:02 interface,info ether8 link up (speed 1G, full duplex) 07-08 14:31:45 interface,info ether8 link down 07-08 14:31:48 interface,info ether8 link up (speed 1G, full duplex) 07-08 14:40:53 interface,info ether8 link down 07-08 14:40:56 interface,info ether8 link up (speed 1G, full duplex) 07-08 14:43:42 interface,info ether8 link down 07-08 14:43:49 interface,info ether8 link up (speed 1G, full duplex) 07-08 14:53:22 interface,info ether8 link down 07-08 14:53:25 interface,info ether8 link up (speed 1G, full duplex) 07-08 15:36:05 interface,info ether8 link down 07-08 15:36:11 interface,info ether8 link up (speed 1G, full duplex) 07-08 15:44:28 interface,info ether8 link down 07-08 15:44:32 interface,info ether8 link up (speed 1G, full duplex) 07-08 16:13:50 interface,info ether8 link down 07-08 16:13:53 interface,info ether8 link up (speed 1G, full duplex) 07-08 16:26:01 interface,info ether8 link down 07-08 16:26:03 interface,info ether8 link up (speed 1G, full duplex) 07-08 17:18:31 interface,info ether8 link down 07-08 17:18:34 interface,info ether8 link up (speed 1G, full duplex) 07-08 17:35:21 interface,info ether8 link down 07-08 17:35:24 interface,info ether8 link up (speed 1G, full duplex) 07-08 18:02:06 interface,info ether8 link down 07-08 18:02:08 interface,info ether8 link up (speed 1G, full duplex) 07-08 18:09:38 interface,info ether8 link down 07-08 18:09:41 interface,info ether8 link up (speed 1G, full duplex) 07-08 19:01:32 interface,info ether8 link down 07-08 19:01:36 interface,info ether8 link up (speed 1G, full duplex)
For grins, I swapped out the MA2500D adapter connected to the router for the MA2500C in case it was a faulty unit. The MA2500C exhibits the same "ether8 link down" issue.
Sorry for late reply.
Looks like the MoCA adapters rebooted when the issue happened.
Could you check the firmware version of the MoCA adapter?
