I have had my 2 units for about 6 month now without issue. We had a power outage in my apartment and now one of my MoCA units is not connecting to the other or the internet.
The one that is connected to my modem/router is not connecting to the internet. The MoCA, SEC, and PWR lights are a solid green. They turn on immediately after getting power, unplugging all but the power cable does not change the lights. And pressing the reset button for 10+ seconds had no effect either.
Is my unit fried or is there a way to recover it? I'm trying to find a solution asap as my partner works from home and the wifi is not strong enough by they're computer to work effectively.
Thanks.
Hi Jon, we will contact with you by email, to resolve the issue.
