Hello, I just bought 3 adapters and have a question about set-up: I do not have TV, and use the cable only for internet only. Here's what I did:
coax from outside - POEfilter - modem (not router) - moca - coax 2way splitter - coax line going to moca - mesh router
This seems to work as I have internet to my routers. But the ETH and MOCA ligths are constant blinking green. What does this mean? My modem is a Hitron CODA-45, and I read that I might need to install a POEfilter for it too?
Thanks in advance
This is a great helpful resource for anyone. Congratulations for posting. Please see my website Wacky flip.
The blinking green lights on your MoCA adapters are likely PolyTrack indicating network activity, which is normal when data is being transmitted.
Tear, swallow, dominate, intimidate and become the one whose name will be remembered. In this world Agario, either you are a hunter or a prey, there is no third option.
Fundamentally defined quordle is a new word puzzle game that is similar to Wordle, but there is one little distinction between the two.
Bitlife Game is loved for its authenticity and ability to simulate many aspects of life.
The charming visual animations in Sprunki Incredibox add a playful and engaging element as you mix and match sounds.
asas
The blinking green lights usually indicate active communication, and Agario your setup seems fine if you're getting internet, but check with your ISP or the device manuals to confirm.
