I am currently installing the goCoax MoCA 2.5 adapter device, and have so far only been able to make it through step four (Check Power LED is green/solid, LAN LED is green/blinking). On step 5, the MoCA LED does not come on. I have read on a couple other threads on here that I should check any splitters to make sure they support MoCA, which they do, so I have no clue what to do next to troubleshoot this. I am including photos below of the MoCA device Frontier originally set me up with, the 8-way splitter and 2-way splitter currently in my setup, as well as the Coax splice device I am using to make sure I am not overlooking something being incompatible.
Geometry Dash is a thrilling rhythm-based platformer that has captured the hearts of millions. Developed by RobTop Games, it offers a free-to-play version of the popular Geometry Dash series, delivering fast-paced gameplay, addictive levels, and pulse-pounding music.
These take away completely from the cluttering mess of a TV stand and save you the trouble of clearing up a table to rest your TV on. All you need is a flat wall and you can hang your set up with ease. This article will be centered around wall mount products meant for TCL sets, be it a 40 inch or a 65 inch TV. For further information, you can check our section about https://wallmountedhub.com/
On the Verizon Fios side, Verizon routers (G1100 and G3100) have two MoCA controllers each, one for LAN and one for WAN. So, for a Verizon router, you can have MoCA WAN and MoCA LAN simultaneously active. You can enable/disable WAN and LAN MoCA interfaces in the web GUI. Just for your information.
I think other broadband router should be the same, can support both MoCA WAN and LAN at the same time?
My home forum is Verizon Fios.
I have some suggestions to make, but I'm curious... Does Frontier not offer ANY documentation for the FCA251 adapters? Do they not provide instructions on how to setup a MoCA LAN when the FCA251 adapter has been used to establish the WAN connection between the ONT and router?
-The current router that connects to Frontier's MoCA adapter is an ARRIS NVG468MQ
-The Frontier device is currently set to WAN
-I am pretty unfamiliar with all of this so this may be the wrong answer, but currently the ARRIS router has the ethernet cable running from the Frontier MoCA device connected to the 'ONT' port. Aside from that, the remaining ports are all open at this time.
-I purchased 2 goCoax WF-803M adaptors. So far, this is all relating to the first one, but I am sure I'll have just as much trouble with the second one, based on my inexperience with this stuff
Reviewing the OP, some things remain unclear ...
You're a Frontier FiOS (fiber) customer, so must have an ONT ... but what are you using for your router? (model #?)
You've mentioned and included a pic of a MoCA adapter supplied by Frontier, the FCA251; however, this device has a physical toggle switch on the same face as its coax port, with possible settings of "Full," "WAN" and "LAN." In what position is it currently set?
To what is the "WAN" Ethernet port of your router connected?
How many goCoax WF-803M adapters have you purchased?
Sidebar: Wow, that 8-way splitter looks way overkill with just 2 outputs used. At a minimum, you'll want to cap each of the unused/open ports w/ a 75-ohm terminator.
