So, I purchased a single GoCoax and like all the reviews and ads said, I plugged it in and expected it work "plug-n-play". Not so lucky. I changed out the splitter, for the different bandwidths, that have been suggested. My gateway/router is through Xfinity and we all know what getting answers from them is like. Needless to say I'm not certain the gateway/router is MoCA activated. In reading different posts about this goCoax adapter, it either needs an activated MoCA gateyway/router or another goCoax adapter in order to work.
Current attempted hookup: Line in ->splitter->(1)gateway/router (2)goCoax->ethernet->laptop
I'm at a loss. I don't necessarily want to purchase another goCoax if it is not necessary. The xfinity gateway/router info is:
Model Numbers: CGM4331COM and TG4482A
Friendly Model Name: XB7
Gigabit Ethernet Ports: 4
Dual-Band WiFi Option: Yes
Maximum Data Throughput: 2.5 Gbps
WPS (WiFi Protected Setup): Yes
Gateway/ Network Management Tool (http://10.0.0.1): Yes
Xfinity xFi Eligible: Yes
Xfinity xFi Advanced Security: Yes
Xfinity app Activation: Yes
Two Total Telephone Ports: Yes (separate Alarm Port)
Battery Backup Capability (Xfinity Voice Only): No
Link Cordless Phones (CAT-iq 2.0*): Yes
Home Hotspot Capable: Yes
Compatible with Xfinity Home : Yes
![](https://static.wixstatic.com/media/a27d24_fa0029da47bf4021998107642fa78ca2~mv2.jpg/v1/fill/w_980,h_1307,al_c,q_85,usm_0.66_1.00_0.01,enc_auto/a27d24_fa0029da47bf4021998107642fa78ca2~mv2.jpg)
![](https://static.wixstatic.com/media/a27d24_cf0f89a6e50949a5ba6f0dfded4c0fee~mv2.jpg/v1/fill/w_980,h_1307,al_c,q_85,usm_0.66_1.00_0.01,enc_auto/a27d24_cf0f89a6e50949a5ba6f0dfded4c0fee~mv2.jpg)
![](https://static.wixstatic.com/media/a27d24_219c708b70ac4fada4f793ccdc0b5b46~mv2.jpg/v1/fill/w_980,h_1307,al_c,q_85,usm_0.66_1.00_0.01,enc_auto/a27d24_219c708b70ac4fada4f793ccdc0b5b46~mv2.jpg)
![](https://static.wixstatic.com/media/a27d24_d9601c7ac1ec41ddb783e08dd7f10b36~mv2.jpg/v1/fill/w_980,h_1307,al_c,q_85,usm_0.66_1.00_0.01,enc_auto/a27d24_d9601c7ac1ec41ddb783e08dd7f10b36~mv2.jpg)
Hello, the tools that will allow you to master the projections of the map are well written article, and also wanted to add about the well-made, durable and withstand the harshness of snow, rain, dirt and everything else you may encounter while traveling. Then you need reliable nebo flashlight review.
This apartment security system has 10 dollar subscription fees which ensure that you have peace of mind for many nights to come. This apartment security device comes with a 5 piece kit which includes a doorbell and window sensors so that you are alerted if some intruder enters your apartment. When it comes to apartment security you always need a device you can trust with your apartment security. It is even better if that apartment security device comes integrated with security system for small apartment here support.
So circling back to resolution - Xfinity said they activated the MoCA remotely. They did not (go figure). I was able to login and activate the MoCA on my gateway/router - plugged the GoCoax in to the Coax in the room I wanted and it worked. Thanks.
I neglected to state I'm looking for solutions...
