See this parallel reply: https://www.gocoax.com/forum/main/comment/603f00d87176e7005ef1b333
Though, if you're installing a MoCA filter on the splitter's input port, the output port isolation becomes less important for the top-level splitter, so a sub-optimal splitter will still work. Otherwise, something like the following would be preferable over any of the above recommendations.
Thank You. I plan on ordering 4 goCoax 2.5 adapters. The splitter will be at poe with no additional splits. I was looking at both of the splitters you suggested, in addition to yours. The BAMF is not available tomorrow through Amazon. Is your second recommendation sufficient? Should I order one of yours too?
https://www.amazon.com/Antronix-MMC1004H-B-Splitter-Frontier-Formerly/dp/B07PNJVKQZ/
Hi John,
You can buy the splitter from our website.
https://www.gocoax.com/product-page/ot-dsp-4
Or from Amazon.
For Amazon, you can try these ones.
https://www.amazon.com/BAMF-4-Way-Splitter-Bi-Directional-5-2300MHz/dp/B017T9KF1S/ref=sr_1_4?crid=3VZGKM9G709TW&dchild=1&keywords=4-way+splitter&qid=1613843339&sprefix=4-way+spl%2Caps%2C197&sr=8-4
https://www.amazon.com/5-2300-Coaxial-Antenna-Splitter-Satellite/dp/B07FDQR7F4/ref=sr_1_19?crid=3VZGKM9G709TW&dchild=1&keywords=4-way+splitter&qid=1613843339&sprefix=4-way+spl%2Caps%2C197&sr=8-19
