Hi all.
I'm having a problem and any help would be appreciated.
I have a pair of MA2500D's, I get a good connection and everything works with 1 device connected to my router through the ethernet port on it and the other device plugged directly into another device (XSX, PS5, Nvidia shield and TV all tested and working).
The trouble comes when I try to introduce a switch into the equation. The switch I'm currently using is the TP-Link TL-SG105S, bog standard 5 port switch. I've tested it on its own and it works however when I connect the downstairs MA2500D to the switch (and the switch to my other devices) I get no connection on any device and the ethernet light on the MA2500D does not light up.
Is it possible that there is a step I'm missing? Is there any advice on things I can try or troubleshooting steps I can take to figure out the source of the problem?
Again any help would be greatly appreciated.
By default, D-ext, D-low, D-high are enabled, and D-ext will be used. The MoCA link rate can be about 3500Mbps. This is the highest MoCA 2.5 link rate. please check the rate. If the rate is lower than this. we have to check splitter and coaxial cable.
Hi, I should have followed this up. The problem ended up being the switch. It had become non functional since i last tested it the week before. I have replaces the switch and this has fixed the issue. A question though. Does the number of bands selected (D-ext, D-low, D-high) have an effect on the available bandwidth / speed / latency? and is there any information for how to optimize settings in the admin portal to optimize the connection between the two boxes.
We have checked MA2500D with TL-SG105. no any issue.
Could you share the buy link of TL-SG105S, we want to verify that.
