I have two different brands of MOCA Adapters. One is an Actiontec ECB6200 Moca 2.0 Bonded adapter and the other is the ma2500c. When I use the MA2500C the initial adapter and the actiontec for my PC, I have to resort to using my built-in moca adapter from my router because the actiontec doesn't recognize the moca for some reason. When I switch them around, the MA2500C eth light flashes green and my computer doesn't get an I.P. I tried to manually set an I.P address, but it didn't work. Am I missing a step?
To test this feature, visit your live site.
Comments (5)
MA2500C should can work with ECB6200. Could you connect them directly with a short coaxial cable and check the MoCA light status?
Looks like your router has built-in MoCA. Could you share the model number of your router?
