I have a problem with local LAN speed. If I run iperf with this command
iperf3.exe -c 192.168.1.245
I get speeds around 125 Mbit/s
When I run iperf with this command
iperf3.exe -c 192.168.1.245 -P 8
I get speeds of around 773 Mbit/s
Which is already much better and would be enough for me...
PHY Rates I actually have like this: +-3600 Mbps (both of them) And the center line values +-700
Now to the problem, I measure this speed on this route: NAS-Router-GoCoax (in)-GoCoax (out)-PC
But if I start dragging files to the NAS with windows explorer (to Synology) I get only 15 MB/s = 120 Mbit/s
Do you know where the problem might be?
Thank you!
Try restarting your modem/router, checking for service outages in your area, and contacting GoCoax support. For reliable and convenient healthcare options, consider exploring Home health care services in Dubai.
I’m also experiencing similar issues with GoCoax’s local internet speed. It seems like there may be some connectivity issues in our area. For faster support and updates, you can check out the tiger 247 platform for troubleshooting tips and solutions.
Experiencing GoCoax internet speed issues? Adding Cable TV to your package might improve stability and give you more value. Contact your provider for solutions!
File transfers to NAS are usually single-threaded TCP connections, which are very sensitive to latency. MoCA networks will add about 3ms of latency, which may affect transfer speeds. If possible, run an Iperf3 server on the NAS. Doing a throughput test may provide further insights.
