Here is the setup. I have a fios router with a moca adapter built in. This has already worked with a fios moca adapter I have purchased previously. I ordered this goCoax adapter as it was the least expensive option (couldn't get the fios moca adapter again). I plugged the goCoax in just like my other moca adapter, the pwr, moca, and lan lights are all lighting up, and flashing for the moca and lan ones. However, the macbook I have the ethernet cable connected to can connect to the moca adapter portal but not the internet, or my router. What could be the issue?
To test this feature, visit your live site.
goCoax and Fios Moca router, no wifi.
2 answers2 replies
Like
Comments (4)
Came across a similar setup when helping someone troubleshoot a MoCA config that wasn’t handing off the WiFi properly from their FiOS router. Turned out the Xfinity connection involved on the coax line was complicating things more than expected. Getting through to real support was harder than it should’ve been, honestly. Found https://xfinity.pissedconsumer.com/customer-service.html while looking for a faster way to reach someone who actually knew how MoCA behaves across split environments.
Please share the model number of your Fios router. We know some Fios router is using a special band for MoCA WAN, to connect the Fios ONT. We need to confirm it is the case or not.
