Hey All,
I am putting a MoCA kit on a FIOS Setup with a G1100 Router. I bought the WF-803M Kit, beside checking the Splitters, will I need to know anything other then checking those?
We are hoping it will be as easy as it looks. I am not sure where the Coax is for the splitter of the house but could it be the Coax going to the Router?
I was trying to find out if I need a POE Filter for FIOS or Not??
Our product should can work with G1100 router. Could you share your network diagram? We can do more check for you.
