I have a direct Coax run from our office to the living room. After installing MA2500D adapters on each end, the highest throughput I can get is 200Mbps from living room to office with frequent drops to nearly 0, and 300Mbps from office to living room using iperf. I updated both to the latest firmware, but no change. Do I need to reduce their TX power since there are no splitters? Also the switches being used on each end have EEE enabled, i have replacement switches that allow me to disable 802.3az on the way, could this be the issue? Pictures below, IPERF screen shots below are Living room IPERF set to server and Office Set to client. Screen shots of both MA2500D configuration and status pages as well..
![](https://static.wixstatic.com/media/89969c_5b1a041ec0f74302a220b27cf4849c70~mv2.jpg/v1/fill/w_421,h_144,al_c,q_80,enc_auto/89969c_5b1a041ec0f74302a220b27cf4849c70~mv2.jpg)
![](https://static.wixstatic.com/media/89969c_58a571cddd38407d9d05f2f1e009a677~mv2.jpg/v1/fill/w_421,h_130,al_c,q_80,enc_auto/89969c_58a571cddd38407d9d05f2f1e009a677~mv2.jpg)
![](https://static.wixstatic.com/media/89969c_b7ed270c3fe84e6babb2f0b91eb394a1~mv2.jpg/v1/fill/w_609,h_396,al_c,q_80,enc_auto/89969c_b7ed270c3fe84e6babb2f0b91eb394a1~mv2.jpg)
![](https://static.wixstatic.com/media/89969c_ec49eb8211064937b2c8b72b3cc40b80~mv2.jpg/v1/fill/w_980,h_232,al_c,q_80,usm_0.66_1.00_0.01,enc_auto/89969c_ec49eb8211064937b2c8b72b3cc40b80~mv2.jpg)
Could you check the MoCA Link rate page. We want to make sure it is good.
